dsm1gturbotalon
- 0
- Jan 1, 2003
Racine,
Wisconsin
Today I installed 660cc injectors and a br fpr on my 90 talon awd. I was making an attempt to get the 255 fp in but couldn't get the fuel fitting off and gave up until tommorrow. I installed the fuel pressure gauge on the fuel filter and started the car up. I had a leak and put some teflon tape on the fitting, tightened everything up and there seems to be no more leaks. The problem is that the gauge is reading about 22 psi at idle. I thought base pressure was about 37psi. Does this seem to be a problem with the install of the gauge or with the fuel pump itself? Does it need to be rewired? I am going to try and get the new pump in tommorrow, any help on getting that fitting loose?
