zedicus
- 469
- 71
- Aug 4, 2011
Garden city,
Kansas
at about 8psi i get a loud pop that sounds like an intake coupler popping off.
i have boost leak tested, changed basically every coupler on the intake, changed the intercooler, changed the BOV. smoke tested, boost leak tested again.
there is a MBC installed but it was in place for one of the boost leak tests and had no issue.
car is set up with MBC to run 16psi. walbro 190 pump, this is my 95 2g car. stock injectors and a 14b.
turbo does not whine, spools good. car runs great and boosts up to about 5 psi perfectly, then from 5 psi to 8 psi is a bit of a struggle then POP! and power loss but engine still sounds fine.
it HAS to be a weird boost leak at pressure but i am out of places to look. the confusing part is boost leak test was done at 28psi and that is over what i am running by a fair amount, so could it be turbo related?
also vacuum at idle looks good on the gauge, boost looks good right up until the pop sounds then the gauge goes nuts until i let off the gas pedal. then everything goes back to normal, rinse repeat.
thoughts?
thoughts?
