13secGST
- 1,111
- 2
- Dec 1, 2002
San Luis Obispo,
California
Ok guys...thought I'd let you see my Dyno graph...and show newbies that just because they put all the parts on their car, it doesn't mean that it will be fast and have lots of HP.
Sorry its so light but just look closer you can see everything.
Now there were also many things wrong with my car at this time.
1. Exhaust leak between Manifold and Head (missing stud for #4cyl)
2. Exhaust leak between Manifold and Turbo (6cm gasket with ported big16g...well its destroyed and 7cm is on the way)
3. Only on bolt was hold on the test pipe to the Catback...that is a story because I just got the RnR downpipe and had the catback cut and modified so it didn't neck down to fit stock cat...well the people who welded on the flange rotated it so it wouldn't bolt up...now its fixed though)
4. Runing 17psi and didn't datalog till after the dyno...found out that timing would drop to -2 degrees and only climb to a high of 8...after dropping the psi to 12 timing dropped to 3 and climbed to 12 and there was NO power difference between the 17-12 psi because the difference in timing was enough to compensate...now it boosts at 13.5 and timing still drops to 3 but climbs to 13...however boost does creep all the way to 20psi in high end...but that will be fixed this week as well.
5. I'm running stock injectors and NO tunning system...this is my BIGGEST problem...
This Tuesday Mike at DSS will have the car he is going to fix an oil leak for me, port the Manifold and fix the exhaust leaks caused by the manifold, port the wastegate opening more so no more boost creep problem, install 660cc injectors.
And my 95Eprom ECU will be sent off to DSMLink on Tuesday so hopefully I will have that by the end of the week as well and my problems will be fixed.
Estimated HP after messing with the logger and gaining more timing is about 245-250 whp.
