looking for the Saskatchewan DSM'S
Anyone intersted in a set of Torque Solution billet alum driveshaft bushings? Should be around $50 for a set. I am planning on buying a set so if anyone else is interested we can save on shipping.
ASAP!!!)#$%
Hey guys in regina.. I am in need of two transmition seals tomrrow! the main shaft in the bell housing and the seal that goes around the t-case(input i think) the one that is down and to the right of the main shaft. FOUND OUT today that is the reason behind my clutch slipping prior to taking off. PM or text me if you got anything 306-591-6261
Need these ASAP
Gentlemen,
Saturday July 2nd My father and I in colaboration with the Regina Beach Supermarket will be hosting our 1st Annual Regina Beach Show and Shine. as of right now 15 dollar entry fee, all proceeds go to the breast cancer society. there will be a concession setup to support the Regina Beach Fire Department. grocery store/gas station is right there...... i do believe we will be accepting cars from 12 -3 prizes to be given out and trophys to be awarded...
Hey guys, I just ordered all the parts for my head from extremepsi.com Next step is getting parts for the block. Anyone have an idea of where I can get some second gen interior parts for me Spyder. Also looking for nice big FMIC, and looking at any other aftermarket parts. Oh and incase anyone here does not know what I am doing....... I am building a 97 Eclipse Spyder AWD with a fully redone 6 bolt engine.
If your not on DSMTuners.com already, you should sign up and browse the classifieds. There are tons of deals on good used stuff to be had.
Check out Club DSM Canada, and post a Wanted To Buy add.
ca.dsm.org
Most of the guys are in central Ontario, but everyones pretty good on that board.
The red one is under a car cover in my driveway. What pissed me off is I finally realized where my oil leak is coming from... Apparently I need to put thread sealant behind my exhaust manifold studs because the people that built my engine never bothered to. Apparently this is common knowledge for most DSM specialty shops, but not for all...
I'M BACK! LOL time to bust out the car, start the repair season early. Garret I'm still taking you up on your offer to help with the harness. You seem to have nothing but trouble for that engine to man, sheesh. Oh and you got me hooked on that gawd damn barbra streisand song!
I didn't know oil could leak through the studs. Any studs in particular? I'm about to soon put mine back on.
Really there shouldn't be any oil coming through the stud unless there was a broken stud there at one point, and someone drilled to far into the head into the oil galley behind it. I'm assuming this is what happened just from the way the oil is spraying, however if this doesnt fix it then I am going to have to pull the front case...
Just incase I am going to take out all the studs and apply high temp liquid thread sealant.
It's only just the one stud. Center-most stud on the bottom row. It goes through into the oil return gallery. Its not under pressure but the oil can wick through past the threads.
No its not that someone drilled out the hole. Its like that from factory.
