VT_4G63
- 56
- 25
- Mar 23, 2021
Saugerties,
New_York
As the title states, I am looking for opinions on what the "best" 4G63 Block/head combo is amongst the various combinations possible by mixing 1G, 2G, 6-Bolt, and 7-Bolt heads and blocks.
I have the parts to pretty much put together any block/head combo possible amongst the various combinations of 4G63 parts.
I'm going to initially run an MHI Evo 3 16G with all the necessary supporting mods. For cams, I'm starting out mild with GSC S1's. Eventually, I might go with GSC S2's.
My goal for the car is to be a fun street car, not a daily or a track car. I'm looking for between 350hp-450hp.
I have an EVO 3 intake manifold if I end up going with a 2G head, whether it's on a 6-bolt block or 7-bolt block. Otherwise, with a 1G head, I'd go with a 1G intake manifold. Either way, I'm running an FP exhaust manifold.
I also have the means to run a 1G 7-Bolt head on a 7-Bolt block if that combo is considered preferable.
My takeaway has always been that 6-Bolts are more stout and 7-Bolts are more evolved (factory main girdle, crank sensor, etc.).
I take "crankwalk" with a grain of salt; I'm aware of it, but I'm not basing my build around it.
Basically, I'm looking for opinions on what combo of 4G63 head/block people would go with if given the option, based on previous experience.
Thank you
Thank you
