jpmxrider489
- 2,410
- 146
- Apr 4, 2010
pittsburgh,
Pennsylvania
So I have a Wally 525,8an feed, 6an return, fic1600 hiz on e85.
At idle I have no leaks anywhere. I did a boost leak test as mentioned in one of my other threads but tested to 30.
My question is if linear fuel pressure is boost plus base, I'm seeing 70-80psi depending on how much boost I run. Now for me to test the fuel system at 80, can I just turn the pump on with link and turn the regulator up until 80 and look for leaks?
In link my fuel pressure is all normal. I'm not running out of fuel. My boost and fuel pressure are equal meaning adding boost to base I get the correct pressure.
But my question is just because I'm not seeing a issue in dsmlink, maybe the pump can still pump enough for dsmlink to correct with a small leak.
Like I said no leak at idle. I bench tested the fpr. I'm mainly concerned about the lines under the car and my sensors.
