MC DGNF H2
- 0
- Jan 3, 2021
Spokane,
Washington
Hello, my name is Devon, I'm 24 and I've been lurking this forum on and off since about '10. Finally decided to make an account now that I've invested some time and money in my DSM. I work for a very small independent shop which I've learned a ton from, I also own a '85 toyota celica GTS which is exclusively a summer car and a '99 subaru forester.
Some background on the car, It's a nearly bone stock early '95 automatic GSX with 137k miles currently on it, build date 4/94. My family bought as my sisters first car back in '05 for $2500. She loved it and drove the hell out of it, parked it in '08 when it started running bad, then gave it to me on my 14th birthday in '10. I knew nothing about fixing cars at the time so it sat in my back yard until '16. I pulled it out of my back yard and took it to my work so I could fix it up and drive it that coming winter.
At that point I did:
This time I decided to be more thorough and do some much needed maintenance:
- 4w Brake job
- All fluids changed
- VC gasket
- Plugs, wires, drive belts
- Rear wheel bearings
- Alternator
- Ignition switch
- Timing belts, idlers, seals, water pump
- Re-capped the ECU
- Drive shaft U-Joints
- Cleaned the intake and intercooler
- Exhaust manifold gasket, bolts and flange gasket
- Went through the entire fuel system
- Cleaned, greased and re-sprung the door latches
- Installed a newer OEM door handle and lock
- Cleaned out all of the drain tubes
