candela
- 3,591
- 3
- May 10, 2002
Austin,
Arizona
I know this isnt very complete yet but Id still like a little conclusion. The rundown: Got the car running with 16g full turbo back 3" w/test pipe, 550's/afc combo...but havent installed my fuel pump yet (dont ask).
I finally got it running good enough to drive but it stutters and has no power. I logged it with the pocketlogger and am very confused. My o2 voltage is very low most of the time (lean) but pulse width is up there. The car stutters with more than 30% throttle past 3500rpm like its running really rich , but the o2's are still saying lean. The whole tim I never get less than 12 degrees timing. but I still got a crap load of knock at 100% throttle applications???? I dont really know.
Im going to put in the pump, charged air fpr and gauge, ant then Ill post my actual logs if to try and get this corrected. I just wanted to get it running as smooth as possible for now.
