lifter problem i think?????
hondakid_2001
64
Mar 24, 2003
Bemidji, Minnesota
okay i have a 95 eclipse GST with a 97 GST motor in it, the motor only has 20,000 miles on it, and it started ticking so i thought okay maybe it is the common mitsubishi lifter tick, but now it is like a horse is troting on my hood after i get it to about 2500 rpm, its sounds like its coming from the head so could it be that i have a bad lifter???? it doesnt sound like its coming from the lower half of the motor at all so i am not too worried about that, but any info would be appreciated thanks
You could pull one spark plug wire at a time to confirm it's not coming from a rod bearing. The noise will stop if it's piston or rod related.
Then do a compression check, if all is good there you will have to pull the valve cover for cam, follower, and valve assembly inspection.
Is the engine running rough?
Cheers,
GTM
okay i cant really do a compression check right now or take spark plugs our or w/e because i have my turbo off because my exhaust manifold is cracked so , but it almost seems like if has to becoming from lifters??? i just don know, and also if anyone knows where i could find a 2G exhaust manifold for a turbo that would help too?????? thanks
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Price is shipped USPS flatrate. Message 702-741-6987.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $240 + shipping and PayPal fees* just replaced the upper bushing with...
  • For sale 4G63 Heads/ head parts
    Heads/ head partsNever ran ready to bolt up 1G head Ferrea dual valve springs/ retainers...
    • Dsm_canadian_mike
  • For sale 2g 2G Spare Tire Trim & Tool Pouch
    2G Spare Tire Trim & Tool Pouch $40 + shipping and PayPal fees* tool pouch has the tools...
  • For sale 2g 2G AWD Fuel Filler Neck
    2G AWD Fuel Filler Neck $65 + shipping and PayPal feesYou must be registered to see...
