LiquidGS-T
- 75
- 1
- Jul 8, 2004
Allentown,
Pennsylvania
the car is a 96 GS-T
OK, we did a full engine rebuild. Stroker kit, Head rebuilt and decked, 272 comp cams, stock oil pump, balance shafts removed, translator w/3g maft, and a 16g. stock lash adjusters, 680s, walbro 190, blah blah blah
Tried to start it up, no compression. I've run into this before. Pulled out the lash adjusters and bled them down the best i could (pin in the top and pump). I got a lot of oil out.
Put them back in the car, fired it up. Had bad valve chatter obviously. We started driving the car and the chatter quieted, car was running smooth. then at low rpm it started to develop a stutter. Compression test showed cylinder 2, 3, and 4 with 150psi, cylinder 1 had almost nothing.
The intake lifters seemed higher than the rest on cylinder one. Pulled them out and drained them again. Put them back in, compression test was great. Started the car ran smooth. Got about 3 blocks with it and it started to stutter again. If you get it moving and take it over 2500rpm it runs smooth. Get below that, its missing. SOMETIMES it pulls out and doesn't stutter at all, but thats seldom. We thought maybe they needed to run a little while. Car's got over 100 miles on it, and no change...
Tried replacing the intake lifters on that cylinder with another pair, but got the same result. The car never had an oil problem or problem with cylinder one...
We ordered 3g lifters for it hoping that they drain better and won't build up like that. Can't figure this one out tho. The oil pressure is normal.
Couldn't find any threads with this problem before.
