1. Join the Community!
1G Liberty shot peening
Posted by SasaniFab, May 27, 2019
Please Support STM Tuned
  1. SasaniFab
    SasaniFab Freelancer
    2,189
    612
    Joined Dec 1, 2013
    danbury, Connecticut
    Before I purchased billet transfer gears in my current trans I had planned on just getting my stock gears shot peened and cryo treated. Since I have several of everything I sent a few sets out and included a few planetary sets. Everything looks awesome. The real question is .... is this all really worth it? Studies say yes .... guess we’ll find out
    Street Build 3K  20
    1992 Eagle Talon TSi
    645 whp · 498 lb/ft · 1G DSM
    Loading...
    Talon96fwd and Hickory-NC-2Ggsx like this.
  2. bastarddsm
    bastarddsm Proven Member
    4,491
    1,039
    Joined Aug 26, 2003
    Mendota, Illinois
    No, the studies do not say yes..... They say that in the application that they studies shotpeening is beneficial. It gives you roughly a 25% increase in endurance limit. If your past that it will not help much, if any.
    Showcar Build 6K  1
    1991 Eagle Talon N/T
    9.805 @ 144.00 · 1G DSM
    Loading...
    b00stedtalon2 likes this.
  3. SasaniFab
    2,189
    612
    Joined Dec 1, 2013
    This is the study I’m referring to..... https://www.machinedesign.com/metals/shot-peening-increases-gear-life
    Street Build 3K  20
    Loading...
  4. donniekak
    donniekak DSM Wiseman
    4,698
    918
    Joined Mar 23, 2008
    Surprise, Arizona
    They aren’t studying the kind of failures we get. No hardening really helps when the root of the tooth is ripping off the base circle. A different tooth profile, better material, or a larger gear are the fixes.
    Street Build 4K  0
    1991 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  5. 1cleangsx
    1cleangsx Proven Member
    215
    112
    Joined Sep 28, 2013
    Cheyenne, Wyoming
    @amsrn13 have you taken your car to the track yet? I’ve been following your progress ever since your stock block fp black setup. Can’t wait to see what your car does on that 6266 auto setup:hellyeah:
    Street Build 1K  11
    1990 Mitsubishi Eclipse GSX
    13.2 @ 104.64 · 1G DSM
    Loading...
  6. SasaniFab
    2,189
    612
    Joined Dec 1, 2013
    These gears will be going in a buddy’s trans Im building. He can’t afford the 1300 jbd gears so for 100 bucks he thought it was worth it.
    Street Build 3K  20
    Loading...
  7. SasaniFab
    2,189
    612
    Joined Dec 1, 2013
    Soon , I’ve been really busy getting my cage finished
    Street Build 3K  20
    Loading...
  8. GSX_Dan
    GSX_Dan Proven Member
    134
    Joined Jun 27, 2004
    Chicago, Illinois
    I've had my transfer gears treated at liberty too, so far only a handfull of 15psi launches but nothings broken. I hope I can come back here a year from now and update with positive results!
  9. turbodsm90
    turbodsm90 Freelancer
    370
    24
    Joined Aug 20, 2002
    Bay Area, California
    Shot peening still doesn't help all that much. I honestly think its a placebo effect for the transfer gears, and you're better off just getting the straight cuts if you're already doing all the labor removing and installing factory gears.
    In a 3355lb 1G cutting mid 1.3 to low 1.4 60fts, the stock shot peened gears STILL cracked at the root. Nothing saved them, even shot a gear out on the dyno and absolutely GRENADED the already hard to find auto transmission.
    2K  0
    1992 Mitsubishi Eclipse GSX
    9.26 @ 148.6 · 1G DSM
    Loading...
  10. SasaniFab
    2,189
    612
    Joined Dec 1, 2013
    I agree totally not worth it on stock gears
    Street Build 3K  20
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
