- Thread starter
- #26
Moonlight GSX
- 566
- 54
- Nov 16, 2010
Hagerman,
Idaho
For those interested in the OVP circuit simulation.
I am currently finding it hard to incorporate it into the stock system without major modifications to the wiring. However, this does not mean that I won't create it or it won't be incorporated into the custom full body harness I would like to start freelancing on.I just came across this little project. Sounds interesting and would definitely look at incorporating the module into my vehicle. Looking forward to any updates.
Thats only for Talons as they use a relay, the Eclipse uses a fat module. I took the resistance wire off and used an led variable resitance unit and this solved mine and i got led's on every flasher goingThey sell led compatible flashers for $15.
For just LED flashers anything is cheaper than my vision. What I am going to do, again for my setup, is to incorporate a DRL setup that was not originally on the car (not this model anyway). Since I do not have any of my harnesses anymore I am starting from scratch and wanted to see if this type of module would be of any interest while I am doing mine.They sell led compatible flashers for $15.
Could almost do a variable resistor from Mouser, or whoever in the UK, as well so that the bulkieness is not there. Nice find though.Thats only for Talons as they ise a relay, they Eclipse uses a fat module. I took the resistane wire off and used an led variable resitance unit and this solved mine and i got led's on every flasher goingYou must be logged in to view this image or video.
Its hidden so it never worries me , once bolted back up you never see it again.Could almost do a variable resistor from Mouser, or whoever in the UK, as well so that the bulkieness is not there. Nice find though.
