Please Support ExtremePSI
Please Support Rix Racing
LED DRL and Flasher Module Creation
Shimmer
30
22
Jul 31, 2008
Vancouver, BC_Canada
I just came across this little project. Sounds interesting and would definitely look at incorporating the module into my vehicle. Looking forward to any updates.
Moonlight GSX
552
50
Nov 16, 2010
Hagerman, Idaho
I am currently finding it hard to incorporate it into the stock system without major modifications to the wiring. However, this does not mean that I won't create it or it won't be incorporated into the custom full body harness I would like to start freelancing on.
EC17PSE
Freelancer
5,734
3,107
Nov 1, 2008
London, UK, Europe
They sell led compatible flashers for $15.
Thats only for Talons as they use a relay, the Eclipse uses a fat module. I took the resistance wire off and used an led variable resitance unit and this solved mine and i got led's on every flasher going
Moonlight GSX
552
50
Nov 16, 2010
Hagerman, Idaho
For just LED flashers anything is cheaper than my vision. What I am going to do, again for my setup, is to incorporate a DRL setup that was not originally on the car (not this model anyway). Since I do not have any of my harnesses anymore I am starting from scratch and wanted to see if this type of module would be of any interest while I am doing mine.
Moonlight GSX
552
50
Nov 16, 2010
Hagerman, Idaho
Thats only for Talons as they ise a relay, they Eclipse uses a fat module. I took the resistane wire off and used an led variable resitance unit and this solved mine and i got led's on every flasher going
Could almost do a variable resistor from Mouser, or whoever in the UK, as well so that the bulkieness is not there. Nice find though.
EC17PSE
Freelancer
5,734
3,107
Nov 1, 2008
London, UK, Europe
Its hidden so it never worries me LOL, once bolted back up you never see it again.
I did buy a potentiometer resister which is knob variable vs internal but i just went with a 1 fits all approach
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned
