GSLENK
- 1,416
- 52
- May 25, 2011
DC,
Maryland
Final update:
After chicking everything but the plugs/wires, it turned out to be plugs and wires. I am using NGK V-power Copper temporarily (BPR6EY, part#) until I get some BP7ES. got a tad better with plugs, back to perfect with wires. Too bad they are only blue and not red
Original Stuff:
I let my car sit for a few days while I was fabbing an exhaust. I start the car, feels normal. Go for some pulls and I get pretty bad stumbling as boost builds. Then the idle seems a bit off, It will stumble a bit at idle also. I haven't had time to log yet, but It appears the stumble is caused by a lean condition. The car never goes too rich.
Idle is mostly around 14.7-8 and then bumps to 15.6 momentarily with the stumble.
I checked a few things, Fuel pressure is good 37psi , spark plugs are fine (I believe a spark issue would cause rich conditions right?)
Fuel injectors were running fine before and they all click when energized.
I just replaced the fuel filter to be safe.
My last BLT was good as of 2 weeks ago (no mods at all since then).
So i guess it down to one of 2 things, o2 sensor on its way out, or my injectors are weird (I think they rarely go bad right?)
Would a failing o2 sensor create these conditions? (it is mounted in the factory o2 spot, and been there for about 6 months to a year)
Would a log tell me if its going bad?
And what else could I look for?
HERES A LOG: starts acting up around 600 seconds. from a cold start all the way through hot idle.
Original Stuff:
