Zerocygnal
- 641
- 1
- Jul 1, 2002
Springfield,
Ohio
Alright..I'll state a bit of the obvious first, explain my problem, and what steps I've already taken.
"When starting out and accelerating, the center of gravity of the vehicle shifts towards the rear increasing the rear wheel load and decreasing the front wheel load. The center differential causes less drive power to be transmitted to the rear wheels resulting in a lower driving torque. At the same time, however the rotational speed difference between the front and rear wheels increases and the viscous coupling operates to limit the differential action of the center differential, securing a supply of drive power to the wheels. In this way, performance when starting out and accelerating is secured...."
Hopefully I am perceiving this as it is meant to be. It was taken out of the DSM manual. What I understand is that the power to the rear wheels is limited under acceleration conditions.
The problem: Weight transfer is reducing rear wheel torque.
I've been practicing my launches and notice that the front end raises up alot. I would say that the wheel well to tire measurement goes from 2" to about 5 possibly 7 inches. I have coilovers w/ KYB AGX with a 2" drop. Short of going all out muscle car ladder bar suspension...how can I reduce the effects of weight transfer?
Is it possible to to increase the power to the rear wheels under an accelerating condition?
If not...what else can be done to the suspension?
And if I'm way off...tell me what I've got wrong.
Ty
Thanks, sorry for the long post
Ty
