launch interface ignition coil taping into?
forcedfed69
91
Feb 23, 2008
nazareth, Pennsylvania
Hey guys, i was tring to install the launch interface today. It says to cut pin wire 10 and 23 and intercept it with the launch contoler. I did as told. but when it hit the set rpm it just killed the car completely untll i let back off of the clutch. could this b cause if you mixed up the ignition coils wires? Like the direction say green and yellow go to ignter trigger one and pink and orange go to igniter trigger two. In there directions trigger one is pin 10 out of the ecu the black/blue wire and pin 23 the brown and red is the igniter trigger two. but could have they mixed up what coil number is one and two? or is there just another place i should try to intercept the signal? Thanks in advanced.
