SNAKE_15
- 572
- 47
- Aug 28, 2012
Bakersfield,
California
Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks?
Yes
2). Verified mechanical timing?
yes
3). Verified base timing?
yes
4). Ignition system
COP or Stock Coil:stock
Wire brand and Age:stock, unknown
Spark Plug brand, type and Gap: ngk standard
5). Motor health (Compression Test)
Cylinder 1:180
Cylinder 2:180
Cylinder 3:180
Cylinder 4:180
6). Performed basic throttle body adjustments?
Idle Switch:yes
Throttle Cable:yes
TPS:yes
BISS:yes
7). Compression ratio
8). Any known bad sensors or brittle wiring?
no
9). Any DTC/CEL codes?
no
10). Electrical system
Car off (not running):
Car running:
11). Base fuel pressure and injector values
Base Fuel Pressure:42.6
Injector Size (cc/min):450cc
12). Properly calibrated and configured wideband sensor
Sensor Brand:aem wideband
Calibration Date:1/4/15
13). Type of fuel
Type:93
Percent of Ethanol:
14). Watched ECMlink how-to videos?yes
So far, I used the evo timing tables and I copied the max tables to the the min octane that way i wont get confused on what values are being used. Anyways, im trying to get wot dialed in, but i keep getting knock and my results always change. In one pull i dont get knock, but the next one i do. im targeting 10.8 afr and i also used the same values for min and max. i only have one recent wot pull that i did today. Any ideas????
Yes
yes
yes
4). Ignition system
Cylinder 1:180
Cylinder 2:180
Cylinder 3:180
Cylinder 4:180
Idle Switch:yes
Throttle Cable:yes
TPS:yes
BISS:yes
no
no
Car running:
13). Type of fuel
Type:93
Percent of Ethanol:
