TupperWare
- 3
- May 6, 2020
Portland,
Oregon
I got a built 2.4 stroker motor, I thought it already had arp mains and a kiggly girdle but I was wrong. I want to put a girdle in but it says to use studs but I don’t want to have to get it line honed. So I have a couple questions, is it possible to use the main girdle with stock bolts? And what’s the limit of the stock bolts if anyone has found it? Also if I can use main studs and torque them to the factory bolt spec (49 ftlb) can I avoid having to get it line honed?
, I believe that was from the act 2600. I think it’s mainly to increase rigidity of the caps when used with a heavy clutch, think about the high horsepower stock blocks that weren’t running girdles, but in a lot of high power builds people will obviously run heavier clutches so they definitely pair well
