GSTjordan831
- 0
- Aug 26, 2020
Salinas,
California
So I just bought a used oem key fob worked perfectly but right after I programmed it the alarm would go off when I pulled the latch to open the hatch and nothing would make the alarm turn off no matter what button I pushed on the fob or even if I turned the car on after like 5min it turned off on it's own I closed all the doors locked it and unlocked it than got in and tried to open the hatch again and boom the alarm turned on again so I had to disconnect the battery to turn it off and since than the alarm hasn't turned on, the fob still locks and unlocks and when I open the hood or hatch no alarm which I just thought was really weird but the reason for this post is when I lock or unlock the car with the fob there are no indications of me doing so the blinkers don't flash when I lock or unlock the car it doesn't beep or chirp when I lock the car which I don't like and i honestly don't know if that's normal I've searched and searched and I just cant find a clip of someone using the fob so I can't see if they're cars blinkers flash or if the car honks, do any of u guys have the oem security/alarm system still with the original fob? and if so do the blinkers flash when u unlock the car or does it chirp or beep when u lock it?
