Please Support STM Tuned
Please Support Rix Racing
Just bought secondhand Alky Control Kit, need to source hose.
Aramane
57
Jun 24, 2010
Des Moines, Iowa
I recently bought an alky control meth kit and in the box was just regular rubber hose. The hoses on the pump were slashed for a quick pull, so I looked at the hose that was still on the pump and it looks like its a nylon lined rubber hose. There's one large ID nylon lined hose for inlet on the pump and one small ID nylon lined hose outlet on the pump.
I'm having problems sourcing these hoses, I need a lot of the small ID hose because I'm going to be routing from the trunk. I need only about 3 feet for the large ID hose.
From my own personal experience don't mount it in the trunk. Its a shitty location because it takes to long of distance traveled to deliver the goods. You can mount the whole system nice and clean under the hood and have that pump deliver through a much more effective short route hose
This is really a moot point...you do realize that your gas tank is at the back right? As long as the hoses are pressurized there will be no ill effects.
E-mail the kit manufacturer, they will point you in the right direction or more likely sell you some hose.
Yeah somethings going in the trunk at the end of this job and I don't want it to be the battery. Too many safety issues and so much $. No room in my cramped 2g bay.
The length of hose that It came with will work for the small ID outlet and there's a lot of it but it's carb fuel hose not fuel injection hose. I was under the impression that you had to use the high pressure fuel injection hose.
Got it figured out, bought 13 feet of 1/4 and 5 feet of 3/8 fuel injection hose. By the way, devils own designed their kit to be used in the trunk supplied by the stock reservoir so there shouldn't be any ill effects as long as it's primed up.
