theoutlaw82
- 52
- 0
- Aug 25, 2009
Gulfport,
Mississippi
I'm trying to compile a list of junkyard mods for the 1G and 2G in order to make a tech article. Basically any parts that you can swap from other cars to this one that are an upgrade. If you guys know anything please share. So far I have.
1G Upgrades
1. 93-94 AWD Front Brakes (1G FWD and 90-92 AWD)
2. 2G Throttle body elbow.
3. 2G Exhaust manifold.
4. 2G O2 Housing
5. 1G 5spd ECU, Fuel injectors ,Fuel Pressure Regulator(if you have an auto) ( must be done together.)
6. 1G 5spd 14B turbo (if you have an auto)
7. 2G Mass Airflow Sensor
8. 92 and up 4 bolt rearend swap (for 90 to early 92 awds)
9. 92-94 M/T D intake cam and C exhaust cam.
10. 1990 Oil filter adapter with external oil cooler.
11. 1G 1.8L EGR block off plate
12. 1G Manual Steering Rack
13. 1G Base Model Doors (No power windows or locks reduces weight)
2G Upgrades
1. 6bolt swap
2. 1G Throttle body
3. 6bolt Connecting rods
4. 1G M/T 14B turbo
5. 1G BOV
6. 92-94 M/T D intake cam and C exhaust cam.
7. 3g rear upper and lower control arms
8. EVO oil filter housing for external oil cooler
9. 2005 Outlander brakes
10. 1G 1.8L EGR block off plate
11. 2G AWD Front Brakes ( 2G FWD)
12. 2G Base Model Doors (No power windows or locks reduces weight)
1G Upgrades
4. 2G O2 Housing
2G Upgrades
1. 6bolt swap
2. 1G Throttle body
4. 1G M/T 14B turbo
5. 1G BOV
