ipWitan
- 54
- 16
- May 31, 2022
MARBLEHEAD,
Massachusetts
This is the Build Thread for Spyder GST. Reply below.
You have to do a battery draw test. I believe it involves disconnecting the negative off the battery and connecting a volt meter between the terminal and the negative wire.The car has a mystery battery drain. A mechanic with whom my father spoke believed that something related to the emissions was causing a metal plate to heated and not turning off (or come on randomly). As a result, over night the battery can be completely drained. I cannot figure out what that would be exactly as Google and the manuals have not confirmed such a device. I will ask the group about this problem when my probationary status is lifted. The car gets hooked to a trickle charger each night.
