Agent11br
- 165
- 12
- Oct 24, 2004
Kalamazoo,
Michigan
98spydert - any news on that write up/vfaq you were working on?
Just curious
Just curious
elementalwindx said:Wow 30 pages now.
I've boosted 16psi on my T-25 and it feels perfect. I noticed when comparing my DSMLink logs between the smic and the fmic, that my intake temp has dropped at LEAST 20 degrees.
Turbocharged said:Why do you guys keep saying that you intake temps dropped xx degrees after the fmic install? Do you have an intake temp gauge that reads temperature AFTER the intercooler? If your refering to the intake temperature that a data logger/dsmlink gives you... thats just the outside ambient temperature (under your hood) as read by the MAF. Your intercooler setup WILL NOT change the temperature of the air before the turbo. Any decrease in the temps read by a datalogger after a fmic install are purely coincidental.
If you are seeing a 20 degree decrease in intake temps, its because the ambient temperature is 20 degrees cooler than your previous run.
Which brings me to this question. Does anyone with this fmic have a post intercooler intake temp sensor? If so, what kind of temps are you seeing? Ive already purchased a different intercooler, but I am still interested in this things performance.
JessesTalon said:well if you have a maf-t and you put it where ppl normally put it... (after the IC) then it does read temps going into the intake manifold...
Thats how I did it... and found my temps dropping quite a from smic to fmic...
90CherryTSI said:I've been thinking about buying the coolingmist digital air temp gauge and mounting it in my TB elbow. I just installed the water/meth injection (single stage for now until I get the FMIC in then DS). I'm almost curious enough to spend the $80 to see the drop. It'd also be a good alarm that the jug is out of water. I could run the test on with/without water to see the temps, before/after FMIC, then before/after dual stage water. It's got to be a big jump in each of the categories, just figure the surface area to cool air stock vs FMIC, not to mention the piping. Hrm....nobody run any tests like this yet?
I didn't know I was working on one :laugh: I think someone else was working on the how-to write up, the guys with the 2G and GVR4 who did the install.Agent11br said:98spydert - any news on that write up/vfaq you were working on?
Just curious
kevingst said:I finally got mine done. I got lazy and bought the Dejon Tool intake pipe and turbo j pipe. I've had the Dave B. uicp for awhile now. I would've liked to have done the passenger side pipes differently, but the uicp didn't really allow for it. I've enjoyed the Dave. B. pipe, but I think it's time to move on to something else. I ended up not using my rre pipes (the old ones from the 16g/14b kit), they were pretty thin. I was having enough problems burning through the 16ga. pipes. I still haven't boost checked the car yet. I'll wait till tomorrow when it's light out... in case anything pops off. Can't wait to get a log on DSMLink and see if my 4k+ knock has gone away. Anyway, I now present the dirtiest engine bay and probably one of the most ragged out cars on this site. But I keep it runnin'
coltboostin said:Couple of things
TO ALL-I noticed that most, if not all of you are using mild steel piping, I hope you guys painted, or had coated the INSIDE of your plumbing, because that shit will rust, even the aluminized stuff, and rust much faster then you would believe.
kevingst said:I've had my rre pipes and the DaveB. pipes on for at least 3 years now. They're all mild steel, and all looked fine on the inside. The rre pipes were somewhat rusty on the outside where the powdercoating had come off, but that's it. I don't know how Dave B. does his pipes now, but back when I got the pipe he only offered 1g or 2g flange. I forgot my reasoning, but I chose the 1g flange. I've already stated I need a new uicp, if I decide to change the bov setup...then so be it. As far as appearance, that's purely a matter of opinion. And PLEASE, someone explain to me how going to a different mounting adapter would make it work better. Because I could've sworn that for the past 3+ years it's been working just perfectly. Coltboostin', do you have any sort of testing to back this stuff up or do you just like throwing your penny thoughts around?
Bostedquest said:Sorry, but what is the sellers ID on ebay that is selling these...
I read about haf these posts, and have heard several names, but no Ebay ID's... the one link posted on the first page was over 90 days ago and no info can be found from that link...
is it tjn115 ? that is the closest looking one with the same demensions... after a while they just all look the same...
coltboostin said:TO ALL-I noticed that most, if not all of you are using mild steel piping, I hope you guys painted, or had coated the INSIDE of your plumbing, because that shit will rust, even the aluminized stuff, and rust much faster then you would believe.
