- Thread starter
- #576
Justin DuBois
- 1,745
- 1,484
- Aug 15, 2019
Oakland,
California
Thank you!Your progress never ceases to amaze me. Car looks immaculate!
Don’t take my word for it, Ask my teenager:
After a global fuel adjustment from -11.7 to 0.00, It went a little too far, but the knock is under better control:I think this is telling me, the E3o2 housing is flowing, the Boost and Lean AFR relative to targets are cooralated. Previous to this mod, the tune was aligned, (richer). The current result is giving a WideBand factor of 10% Lean, so I'm going to start with a global fuel adjust - split the difference +5% and see what that does.
One wrench! You should see the pile of tools I just made pulling the lower timing cover to replace the crank sensor in the Kiggly adapter.I hate when those strip out!
I mostly ground down the spikes on one of these and drilled out the stripped threads for a press fit from the back. This way loosening it is still a 1 wrench operation
I also had a buddy put a shoulder bolt in that location and then just put a jam nut on the tensioner bolt. Worked good too.
Looks wrong to me. Did you ever find out if that is on purpose? I'm surprised nobody answered here or in the other thread you started for it. Maybe it's to simulate a high duty cycle? Or to simulate a heavier spring?I’d prefer this open more. Is this a normal amount?
The WG actuator I have is off of a 14b, so it could be that. There is more movement to be had in the flapper range of motion - the actuator just isn't extending far enough. I think I need to try and locate a WG actuator more appropriate for an E3 - turbine housing. A stronger spring could also be good. There is no need to start opening before 1.0 bar.Looks wrong to me. Did you ever find out if that is on purpose? I'm surprised nobody answered here or in the other thread you started for it. Maybe it's to simulate a high duty cycle? Or to simulate a heavier spring?
I think this is gonna be good - fingers crossed.When I get time and space, I’ll be doing the same sensor setup on my ‘96.
You’re efforts with RRE are certainly valuable contributions to the community!
Bit of a heart race on the freeway, when you realize the clutch feels like it works, but you can’t get neutral. Then, after you yank it into neutral, the only way to get a gear is to rev match and shove, shove again, and finally get it to crunch into gear.
Finally in the drive, it stalled in gear.
I was about to transition from one interstate to another, going farther away from home. Voice command to waze to re-route home, quickly showed me a way back with mostly right turn stop signs. Luck and some emergency flashers got me back on the freeway going the other way without stopping - 2nd gear. Another blip and a jump to 4th gear gets me back to the off-ramp closest to the house, then two more 2nd gear rolling stops to get to the driveway. No lights, mild traffic, and the rest I had to manage with luck.Did you have the pleasure of needing to stop at a red light during this experience ?
That's what it was with my 1965 Hi-Po Mustang. But with our DSMs I would suspect the slave cylinder first! Did you check that already?I suspect something fell off.
Yeah, the master and slave were replaced a little while back when the car was in John's shop in LA. No clutch issues on the 6hr drive home, just lately after some power tuning.That's what it was with my 1965 Hi-Po Mustang. But with our DSMs I would suspect the slave cylinder first! Did you check that already?
