Justin DuBois
- 1,702
- 1,454
- Aug 15, 2019
Oakland,
California
Justin DuBois - DSM Profile "ITFLYS"
Side Post: 2G Front Seats
01. Sparco R100 install on Wedge brackets (start)
Side Post: 2Ga - H3 - LED fog light bulbs
02. Yellow H3 fog light bulb install
03. Carpet cleaning
04. Sparco R100 install on Wedge brackets (continues)
05. Sparco R100 install on Wedge brackets (completed)
06. PiLink - Stack Lap Timer (start)
Side Post: GSX - Fuel level sender(s)
07. Fuel supply maintenance
08. PiLink - Stack Lap Timer (CAN bus)
09. PiLink - CarPlay
10. PiLink++
11. PiLink++ Stack Lap Timer (working)
12. SMOG - July 31, 2021
Side Post: Where to get 2G restoration parts - Stock Body
Side Post: Sunroof delete - Roof swap
Side Post: Looking for a quality Body Shop
13. BodyShop (Before) - Aug 28, 2021
14. BodyShop (Headlights found)
15. BodyShop (Trim Parts removed)
Side Post: MB914056 Glass holder (exterior door trim)
16. BodyShop (Bare metal)
Side Post: Anyone got a source for this trim rubber?
Side Post: Cowl Cover parts
17. BodyShop (Cowl cover)
Side Post: Side skirt clips
Side Post: Factory Paint Codes?
18. BodyShop (Paint day)
Side Post: Interior Grey Plastic Paint Color
19. BodyShop (Ashtrey lid)
20. Hood latch spring
21. Body Shop (Hood pins and Fog Lights)
Side Post: Eclipse 2Ga door caps - (not Talon 2Ga door caps)
Side Post: Drip Moulding re-finish / restore
22. Powder coated wiper arms
23. BodyShop (Final) - Jan 31, 2022
Side Post: Steering wheel and Shifter leather
Side Post: MR217022 Sunshade slider (spring loaded clips)
Side Post: Headliner Clips
24. Headliner Installed
25. Re-stud rear wing - wing install (started)
Side Post: CF Hood - radiation barrier - heat blanket.
26. Heat Blanket installed
Side Post: MU470013 Interior Trim Clip
Side Post: Interior screws - with snap on plastic covers
Side Post: Pins in the lift gate to open the cargo cover?
Side Post: Screws with Grey plastic covers for - door panels, center console and rear panels
27. Privacy cover and rear interior (complete)
Side Post: Rear wing - what are poeple using for the gasket between the wing and body?
28. Rear wing gasket - wing install (complete)
29. Hood struts - installed
Side Post: 2G - injector circuit malfunction DTC
Side Post: ABS light
30. ECU - Cyl2 injector circut malfunction
Side Post: No ECU installed - Will somthing die if I turn the Key On?
31. Hood details (Blanket and Washer hose retainers )
32. Kiggly crank sensor and timing belt (start)
33. 1G Throttle Body - Swap in rebuilt assembly
Side Post: 6 Bolt with a 2G motor mount modified for the timing belt tool
34. 6 bolt Timing Belt Cover - modified
35. Hot parts hate me so much
36. Big-SERT head stud repair
Side Post: OEM Heat shield refinishing
37. TD05H teardown (start)
Side Post: PS Pump (Turbo)
Side Post: PS Pump (Turbo) pressure switch wire
38. PS Pump, Alternator, Belts and Pulleys
39. TDO5H teardown (cont.)
Side Post: Washer nozzles (that don’t suck)
40. Washer Nozzles (finish)
41. Hood Latch install (start)
42. Hood Latch install (finish)
Side Post: AEM Adjustable CAM gears
Side Post: Side view mirror plug and nut cover
43. Interior Mirror Trim
44. 1G CAM mod for 2Gb CAS, and Cyl 1 Exaust Valve Seals
45. 2Gb CAS harness in a 2Ga
Side Post: TDO5H Turbo balancing
46. TD05H - build
Side Post: O2 housing for E3 TDO5H in a 2G
47. Downpipe rehab (start)
48. Manifold and TD05H - Installed
49. Downpipe rehab (finish)
50. Stock fan Clearance
51. Test Drive
52. Scope work on sensors (start)
53. Parts manual PDF
54. Muellerized (start)
55. Another TD05H tear down (start)
Side Post: MHI-TD05H-Big16-vs-18g-vs-20g
56. 2Ga Door caps located
57. 4G63 on a wall (start)
58. MHI-TD05H E3 Turbine and 02
59. Muellerized (creative destruction)
Side Post: Power Steering return hose
Side Post: Dash Cluster instruments
Side Post: EVAP, FPS, and EGR bracket bushings
60. 20G turbo build (start)
61. E3-o2 (start)
62. OHLINS assembly (start)
63. E3-o2 (finish)
64. OHLINS assembly (finish)
65. Muellerized... teamwork
66. Don't take my word for it -
67. Clutch replacement (start)
68. Clutch replacement (finish)
69. 1st RaceRender 2-3 full pull
70. SMOG prep
71. SMOG result
72. Fuel Pump upgrade
73. Reset SD - start calibration
Side Post: What causes noisy airflow high in the RPM band to redline?
74. ECU Boost Control setup
75. Replace MAP mid calibration
76. Restart calibration
77. Calibration complete - Goodby 2023
Side Post: EVO8 timing in a 1G
78. Tuning - Timing
79. ProSpark 9100 - plug wires
Side Post: MLS vs Composite Head Gasket
79. Radium ORB fuel rail install
Side Post: Can new OEM 95 pistons be purchased?
Side Post: Smoke on cold start
03. Carpet cleaning
10. PiLink++
46. TD05H - build
51. Test Drive
61. E3-o2 (start)
63. E3-o2 (finish)
70. SMOG prep
71. SMOG result
78. Tuning - Timing
