99 gst spyder
- 522
- 0
- Jul 12, 2007
st. paul,
Minnesota
Okay, I have two slim fan that wired to a relay to the radiator harness. I follow this setup and seems like it's working fine. The only thing I did a little different is that I'm using two fan instead of one.
From the fan:
Basically I connected both fan power wires together making it into one. And both ground wire together making it into one. Then both the ground wire goes straight to the negative on the battery and both the power wire goes to the relay terminal # 87.
So, my question is, will this also work without blowing any fuse or anything running two fan to the stock passenger harness with the relay?
From the fan:
