13secGST
- 1,111
- 2
- Dec 1, 2002
San Luis Obispo,
California
ok...this is what happens i reverse into my gargage every night and my drive-way is big and slanted...I am in my driveway then I stop switch to reverse turn the wheel all the way to the right back up into my garage.
when I switch to reverse and back up sometimes I don't give it a whole lot of gas but I am letting the clutch out slow and the car shakes like a motha f*cka. is it just me kinda stalling? it just wierd cause I've never felt that before...I mean it SHAKES and rattles the whole car...when I push in the pedal it goes away. So Im not to worried but it happens more often then i'd like and it just seems wierd that it would only do that in reverse and not other gears cause its not like I give the car more gas while releasing the clutch other times...and I never stall the car.
Other thing is in the morning when engine is cold and i first start the car if I put the clutch in the revs will jump up about 300 more rpms then if I let it out cold idle is 1200 vs.1500-1600 (normal when warm is 500)
Also I have an ACT 2100
