jcarmichael
- 380
- 0
- May 3, 2011
Greenwood,
Indiana
subject pretty much says it all, but basically I got a non turbo block and head, neither in any good shape but for 100 dollars I got everything out of it cams and crank. The crank is already ready to go had to have some work done to it but nothing bad. however I am thinking of sending the cams to delta to get them to regrind them to 272 cams. I know the non turbo cams are a bit different then the turbo cams. Will it be an issue?
also on a side note, does anyone know the powerband on there 272 cams? I was thinking of going with the kiggly street springs, if the power band on the cams is going to be low end, I am not sure I will need the ability to wrap out to higher rpms.
