Is it just me, or is it the car?
airkyd
163
Jun 4, 2002
Richmond Hill,
I seem to have this really annoying problem... When I try to shift really fast I get a grinding noise. This especially happens in first gear, and sometimes in second... I rarely hear it in the other gears. Pretty much what I mean is I slam on the clutch and shift to first is about 1/4 of a second it will grind. This is really annoying when I try to make a quick start and I didn't already have the car in gear with the clutch down. A mechanic told me that it's my clutch and that if I want to shift faster, I need a stage 2 or 3 clutch that will engage faster and is made for racing. I have also seen some posts about this BG syncroshift stuff... will that solve my problem? If so, where can I buy it? If it won't, any other suggestions?
Thanx.
Your mechanic knows crap about these cars. BGsyncroshift will help the problem, but if your car has high mileage, your tranny may need a rebuild soon. Most everyone with the early year DSM suffers from the same problem - I know I do. Pick up some BG (you can get it at www.machv.com) and see how much of a difference it makes. You likely won't be able to shift as fast as you'd like to until you get a rebuild. I'd recommend looking into a www.teamrip.com or www.bmtranny.com rebuild.
  • For sale 4G63 Auto W4a33/F4a33 parts
    W4a33/F4a33 parts1G Auto transmission pan $20 2G Auto transmission pan $20 Center support...
    • Dsm_canadian_mike
  • For sale 4G63 1g/2g/Evo launch control device
    Launch control device. Installs between clutch master and slave. Adjustable on release. Can...
  • For sale 2g 2g GSX downstream Denso 02 sensor
    2g GSX downstream Denso 02 sensor. New. Probably 15 years old. No Chyna or off country built...
  • For sale 4G63 Greddy Boost Control valve
    Greddy Profec boost control solenoid. It may fit other controllers. Pic of the connector for...
  • For sale 1g 1g FWD fuel hanger with line.
    1g FWD fuel hanger with OEM line. Including OEM Phillips screws. Excellent condition. Price...
