Bigwilly6754
- 129
- 2
- May 28, 2002
i got my FP green still sitting on my workbench waiting to go in !!!!
First of all quit wasting people's time with these questions and turn up the freakin boost. If you knew how to tune your car then you would know that you can run more than 18psi on pump gas. I run 20psi daily in AZ. Now I know you can run more with that cold weather in MN. Going to a small turbo isn't gonna make you any faster. The Green is a badass turbo. Geez it hate it when people always blame the turbo.Originally posted by Mistaspakles
I'm debating whether or not to get rid of my Green for something smaller. I'm debating this because my car is a street car and I never go over 18psi. Am I wasting the potential of my Green by not going over 18psi? On pump gas and 18psi, I was only able to make 310whp. Would I have better results with a different turbo at 18psi and pump? If so, which should be my turbo of choice?
K&N, DSM-Performance intake pipe, FP Green, Big Greddy FMIC, UIP/Greddy Type-S, 60mm TB Elbow, 1G TB, 1G Intake Mani, 1G Head, ARP Head Studs, 1G Rods, ARP Rod Bolts, Polyurethane Motor Mounts, Magencor 8.5mm wires, Denso 660 injectors, Web Cams 546/547, Quaife LSD, RPS Stage 2 Clutch, Ported Exh mani, AHP O2 w/Tial 40mm WG dump to atm, RRE DP, Apexi N1 Exhaust, Walbro 255LPH, Apexi S-AFC, MBC, B&M Short Shifter, Greddy EGT/Boost Gauge
