Nate355RS
- 446
- 50
- Oct 25, 2012
Salem,
Virginia
I have Galant VR4 and I can't seem to find the cause of an intermittent no start. When I try to crank it one of three things happens:
1. Nothing.
2. I hear the relays click but the starter doesn't turn
3. It fires right up
If it doesn't turn over I just keep turning the key off and on until it finally cranks. I've checked the starters and relays and they seem to be good, so I'm thinking it's something to do with the Apexi turbo timer the previous owner installed.
I attached a pic of the turbo timer wiring. The black and blue connector above my hand is coming straight from the ignition switch. The white wires at the bottom of the connector are spliced into the blue, red, green and white wires in my hand. Red always has 12volts, blue and green only have 12volts when the key is turned to on. Not sure if this is how it's suppose to be hooked up or if it's my actual problem, so I'm open to any help you guys can offer.
1. Nothing.
