93RS
- 140
- 2
- Oct 3, 2011
Brandon,
South_Dakota
My 1g has begun to run like crap It's mostly stock with a MBC set to 11psi, UICP, and a 2g tb elbow. My issue that I'm having is that when I get into boost it will cut out real hard, almost like fuel cut... The Idle is also all over the place. Somedays it will idle normal and when you get into boost it will run like it a dream. Then within that same day It will start idle surging and when you get anything over 3-5psi and it cuts out bad. Feels like ignition to me, but it seems to be weather dependent. I have done alot of searching and I've found a couple of possibilities.... Boost leak, obvious but it seems to inconsistent to be a BL, Coil Packs, Plugs and wires are new, Fuel Pump, brand new fuel filter. Not sure where to go I just want my baby running right again.... Any help is greatly appreciated!!! THANKS
