intake for spyder
dsm_eclipse
May 26, 2004
warner robins, Georgia
Does any one know if the make an intake for a n/t spyder eclipse it for my friends car and we cant find one any one know if the even make one? :dsm:
if im not mistaken the nt spyder is a 420a
so any 420a intake mani would work :thumb:
it wont fit because it is not a 420a it is a 2.4 sohc motor not the doch 420a motor :thumbdown
ok im sitting here at my computer looking at my misu. 97 eclipse spyder service manual, and unless my maual is incorrect, and i dont see why it would be, it says that the na spyder has a 2.0L and the trubo has the 2.4L
i coppied, pased, and underlined where it discusses the motor sizes :thumb:
(this is from the the 97 eclipse spyder volume 2 electrical)
,‘.j ,, ., 2,
CHARGING SYSTEM SERVICE SPECIFICATIONS ,. . . . . . . . : . . . . 15
<2.0L ENGINE (NON-TURBO)> . . . . . . . 3
TROUBLESHOOTING . . . . .‘. . : . . . . . . . 1’. : 1 16
GENERAL INFORMATION . . . . . . . . . . . . . . . . 3 ‘&l c: : I
IGNITION SYSTEM
GENERATOR . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 <2.0L ENGINE (NON-TURBO); . . .t :. 43
I+ (. d ‘ ,.,
ON-VEHICLE SERVICE . . . . . . . . . . . . . . . . . . 6 CAMSHAFT POSITION ‘SENSOR . . . : .:. . . 51
Generator Output Line Voltage Drop Test . . . 6
CRANKSHAFT ‘POSITION SENSOR . . . . . . 52
Output Current Test . . . . . . . . . . . . . . . . . . . . . . . 7
SERVICE SPECIFICATIONS . . . . . . . . . . . . . . 4
TROUBLESHOOTING . . . . . . . . . . . . . . . . . . . . 5
CHARGING SYSTEM <2.0L ENGINE
(TURBO) AND 2.4L ENGINE> .
. . . . . . 13
GENERAL INFORMATION . . . . . . . . . . . . . . . 13
GENERATOR ,.......................... 22
ON-VEHICLE SERVICE . . . . . . . . . . . . . . . . . 17
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Output Current Test . . . . . . . . . . . . . . . . . . . . . . 18
Regulated Voltage Test . . . . . . . . . . . . . . . . . . . 20
Waveform Check Using an Analyzer . . . . . . . 21
KNOCK SENSOR . . . . . . . . . . . . . . . . . . . . . . . 53
ON-VEHICLE SERVICE . . . . . . . . . . . . . . . . . 44
Ignition Coil Pack Check . . . . . . . . . . . . . . . . . 46
Ignition Secondary Voltage Waveform Check
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 48
Spark Coil Test . . . . . . . . . . . . . . . . . . . . . . . . . . 44
Spark Plug Cable Resistance Check . . . . . . . 45
Spark Plug Check and Cleaning . . . . . . . . . . 46
Spark Plug Test . . . . . . . . . . . . . . . . . . . . . . . . . . 44
SERVICE SPECIFICATIONS . . . . . . . . . . . . . 44
CONTINUED ON NEXT
i coppied and pased, and underlined where it discusses the motor sizes :thumb:
