Bdi
- 3
- Nov 30, 2020
Glendale heights,
Illinois
I do not know what steps need to be done when installing the Studs. Is it just put em in with some anti-seize? Torque specs?
This, plus they make everything look much cleaner than your stock rusted nuts.A good idea is to replace the nuts with copper flashed exhaust nuts as they are softer and take the heat better and will never ruin studs. I use them on everything hot and currently never had an issue thus far thankfully
I've watched your Videos before actually the oil pan one cuz I am also `doing that too.When i first did a manifold i had already worked on cars for years but a turbo car was different to me. Its a little cramped in there and its best to disconnect the battery as your right near the alternators power wire. Some bits can be tricky but its not as bad as some other cars thats for sure. Just take your time. If you think its tight do it back up and try not to snap the old studs off.
Awesome. Much nicer to have a larger pan and also fully contained oil in the pan at all time.I've watched your Videos before actually the oil pan one cuz I am also `doing that too.
