talontuner1997
- 149
- 0
- Oct 19, 2006
St. Catharines,
Ontario_Canada
Hey guys i recently did a 6bolt swap on my 1997 tsi awd. Im having problems with the car not starting now. The car is getting spark but im pretty sure the injectors aren't firing. I sprayed the filter with ether and the car almost started so i know theres a problem with the injectors. I am also running ecm link.
So far i have checked the following for problems.
Cas
Coil pack
firing order
fuel pump
transistor
injector resistor pack
MFI relay
Im going to take the cas off tommorow and spin it by hand then use a meter to check to see if the ecu is grounding the injectors. Any other ideas?
Cas
Coil pack
firing order
fuel pump
transistor
MFI relay
