1. Join the Community!
420A Injector Size
Posted by BLACK'98DSM, Apr 16, 2019
Tags:
Please Support Southbay Fuel Injectors
  1. BLACK'98DSM
    BLACK'98DSM Proven Member
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    What cc injectors came stock on the 420a? How can i tell if I have the stock injectors, and what would be a good replacement for them? Best performing ones?
    Street Build 908  8
    1998 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    105  6
    2009 Troy Bilt Bronco
    rwd · automatic · Misc Vehicles
    182  1
    2012 Murray Explorer Dune
    Loading...
  2. dustyboner
    dustyboner DSM Wiseman
    952
    381
    Joined Mar 13, 2016
    abq, New Mexico
    stock is 235cc
    stock injectors will have grey tops and
    on side of the injector will have a chrysler symbol and the mitsubishi part number 4669011 (actually part number from ASA is M04669011)
    the other side will have the bosch part number 280150965
    BLACK'98DSM likes this.
  3. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    Would putting 500cc help my performance?
    Street Build 908  8
    105  6
    182  1
    Loading...
  4. shinzon
    shinzon Proven Member
    271
    48
    Joined Sep 11, 2006
    St. Petersburg, Florida
    No, not unless you have a reason to increase the injector size (i.e. turbo upgrade requiring more fuel).
    888  2
    1996 Eagle Talon TSi AWD
    awd · automatic · 2G DSM
    458  1
    1997 Eagle Talon TSi AWD
    Loading...
  5. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    I have a full intake and a full exhaust system. So my engine puts in and puts out plenty of air, so the only thing I'm really lacking is more fuel. But I don't want to spend that money for no reason.
    Street Build 908  8
    105  6
    182  1
    Loading...
  6. shinzon
    271
    48
    Joined Sep 11, 2006
    Do you have anything to log your fuel trim and injector duty cycle? Any OBD scanner than can display live data would suffice. If you find that your injectors are nearly maxed out with your current setup (duty cycle near 100%) then it may be worth upgrading your injectors, but 500cc would likely be too big. You'd need something to tune the car for bigger injectors after the upgrade, of course.
    888  2
    458  1
    Loading...
  7. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    What size do you have in mind?
    Street Build 908  8
    105  6
    182  1
    Loading...
  8. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    Street Build 908  8
    105  6
    182  1
    Loading...
  9. silvreclips
    silvreclips Proven Member
    917
    89
    Joined Jul 19, 2005
    Greenville, South Carolina
    Like already stated, upgrading injectors will most likely be a waste of money. You first need a wideband to see what your AFR is under WOT. And if you find that you need to adjust that. You will need to look into a tuning solution. The stock injectors should have enough head room to slightly tweak the AFR if you find it not in an acceptable range.
    Now, with all that said, no one retunes these cars with only an intake and exhaust. Once you start changing cams etc you may need to make some adjustments.
  10. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    Cams have been replaced, and decked and polished heads.
    Street Build 908  8
    105  6
    182  1
    Loading...
  11. dustyboner
    952
    381
    Joined Mar 13, 2016
    abq, New Mexico
    I just noticed ^^^
    Max for Stock 235cc injectors @ 90% duty cycle::
    180 Hp @ crank
    which is about 150 Hp @ wheels
    So how did you manage 208 whp on the stock injectors?
    At your power level, you would be maxing out 30# injectors @ 90% DC
    To be at a safe 80% DC, you would need 34# injectors.
    I would either go with
    RC 35# injectors
    or
    Bosch 36# injectors (Part # 0280155868)
    You will for sure need some way to tune the fuel. a 36 pounder is 50% larger than stock.
  12. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    The reason I was asking for how I can tell if I have stock injectors is because the owner before me did alot of upgrades he didn't tell me about. I'm not sure if he did injectors or not but I will have to look into it.
    But I guess the assumption is that they're not stock...
    Street Build 908  8
    105  6
    182  1
    Loading...
  13. silvreclips
    917
    89
    Joined Jul 19, 2005
    I sure would like to see a full mod list for a 420a that is putting out over 200whp NA. And on a stock ECU at that. I am very skeptical that this car is putting out that much power.
    I think Bullet is still the only person to break the 200whp barrier with a NA 420a.
  14. dustyboner
    952
    381
    Joined Mar 13, 2016
    abq, New Mexico
    courtesy of 2gnt.com
    I'm pretty sure the dyno is from was done in 2010 with this mod list:
    (car ran 13.231 @ 106.09, numbers may changed since then)
    Current mod list for the car:
    Trans Modifications
    Quaife LSD
    NON modular clutch set-up; Audi PP, T4 Dodge disc, Neon Flywheel
    Polyuerathane motor mounts (sides)
    solid roll stop (front) Energy suspension filled with pl-400 (rear)
    Engine Modifications
    JE 12.1CR pistons
    Crower 3 cams
    Stainless valves
    .020 off head
    5 angle valve job
    AMM port and polish (intake and exhaust)
    MLS Head gasket
    Of course, full rebuild on bearing etc. (stock)
    PT Cruiser lifters and rockers
    Eagle rods
    Outside:
    AF/X pulley
    MSnS
    Mustang 450cc injectors
    Mustang 65 mm TB
    AMM Intake
    AEM adj. cam gears
    Mark Peachy air horn intake
    Catch can
    Mark Peachy LTH
    2.5 modified downpipe back exhaust
    No power steering /AC
    Honda “race” radiator
    Snowmobile battery
    Summit heat wrap
    Chassis Modification
    Teins and ad.j KYB’s (1.8 drop) in front
    Stock springs adj. KYB in back
    Upper strut bar
    Interior Modifications
    Remove passenger air bag; replace with modified sheetmetal gauge panel
    Remove rear seat
    Remove passenger seat
    Remove carpet
    Gut door
    Exterior Modifications
    Remove wing
    Lexan rear window
    Carbon fiber hood
    Fiberglass hatch
    [​IMG]
    silvreclips likes this.
  15. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    Sorry about the torque, I meant to type 187.6. Nut nonetheless, the horsepower is correct.
    I have attached the stock specs below. That is only +68 more horsepower. For whatever reason that sounds so impossible to you; not to mention you are tuners, so then you should know with a little (or alot) tweaking anything is possible.
    And the only things my DSM profile lacks is my sparking system and oil system.
    Street Build 908  8
    105  6
    182  1
    Loading...
  16. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    I'm 100% sure that you meant with tons of psi, but I'm just saying It's very well possibly to do over a period of time and multiple hands on deck.
    Street Build 908  8
    105  6
    182  1
    Loading...
    DSM B likes this.
  17. ChessmoDSM
    ChessmoDSM Supporting VIP
    193
    126
    Joined Apr 22, 2017
    Burlington, Vermont
    Do you have Dyno results to prove the HP you are putting out? Like others I am very skeptical..
  18. silvreclips
    917
    89
    Joined Jul 19, 2005
    The problem with the 420a is that bolt ons really don't do much for the motor. For whatever reason, Honda motors do very well with bolt ons and see good gains. The 420a doesn't respond as well, that's why most of us turbo them. With a built borrom end they take boost very well and make good power.
    Regardless, I really don't care what the car does or doesn't make for HP. To answer your question, you first need to find out IF you are running out of fuel by logging the AFR at WOT with a wideband. And then checking your injector duty cycle to see if you have any room to add fuel (ONLY IF the AFR is not where it should be).
    Just throwing in larger injectors is not the right thing to do.
  19. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    Thank you for being specific. That's pretty much all I needed to know, and I wasn't trying to cause any problems. I try to be very helpful on this site and I have made may friends doing so, so lets just keep it that way. Doubt me if you want, and with reason. But I know what I know and it matters to me.
    Street Build 908  8
    105  6
    182  1
    Loading...
  20. dustyboner
    952
    381
    Joined Mar 13, 2016
    abq, New Mexico
    the reason its hard to believe your putting down that much power is because, going of your mod list, your on a stock ecu.
    Since everyone knows that bullettdsm is a top expert of this subject so here is a
    quote from bullettdsm
    Also your mod list has listed:
    - Summit Racing headers
    - Summit Racing 272/272 cams
    Summit doesn't sell either one of these parts. Summit doesn't sell any 2g cams. They also don't sell any header for the 420a eclipse.
    I have never seen or heard of 272/272 cams for a 420a. 272s are a 4g63 cam.
    Even with a custom grind 272 for the 420a, chances are you would need a standalone ecu for the car to run right.
    Mello likes this.
  21. dustyboner
    952
    381
    Joined Mar 13, 2016
    abq, New Mexico
    not that it really matters but that should be more like +90
    import tuner did some dyno testing, stock = 113 whp
    with an intake, exhaust, header and a tune up = 119 whp
  22. ThunderChild
    ThunderChild Supporting VIP
    2,427
    639
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Back when we rebuilt my then friends 98 gs, we took it to my dyno class, and managed to out down 150hp at the wheels. It had an intake, header and exhaust, but was otherwise a stock rebuild.
    I'm still skeptical of that hp number, because the car was slow as dirt, when it was bone stock it was a quicker car. If you've had it dyno'd, it's possible the dyno did not have the correction done, or it wasn't calibrated. Either way, I'd recommend getting a wideband first, then an engine management system so you can effectively take advantage of your modifications.
    Street Build 106  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    229  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 743  7
    1997 Mitsubishi Eclipse Spyder GST
    Street Build 942  1
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 2K  10
    awd · manual · 1G DSM
    Loading...
  23. Mello
    Mello Proven Member
    865
    189
    Joined Jul 4, 2003
    Albuquerque, New Mexico
    Hey don't forget the 800 watt JBL amp, all the speakers as well as the R Racing sterring wheel cover or the shift knob. Reading through this thread & the 420A max hp thread questions & statements leaves with a question out of curiousity for myself. You didn't include it in your profile but if you don't mind, how old are you @BLACK'98DSM?
    ThunderChild likes this.
  24. BLACK'98DSM
    316
    72
    Joined Feb 9, 2019
    Hoover, Alabama
    https://www.summitracing.com/parts/dcs-mhc4001/overview/year/1998/make/mitsubishi/model/eclipse
    I don't want to continue arguing, but there they are.
    Street Build 908  8
    105  6
    182  1
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned VR Speed Factory WheelWell.com White Shed Speed
