Blinkyblinx9
5+ Year Contributor
- 129
- 27
- Jan 22, 2019
Clinton,
Iowa
What do we know about the 4th gen EGR valve. I did some rough looking around online but wasn't able to find any definitive specs. The info I'm interested in specifically is whether or not the bolt holes and ports line up and how does the solenoid operate. From what I could find the mounting pattern looks really close and it appears that the valve is actuated by a stepper motor similar to our IAC. If it's as it appears then I'm fairly positive that when I switch to TBW that I can finangle my aftermarket ECU into operating it but I dont know what its maximum switching frequency is or anything.
The idea is to eliminate the EGR hoses and see if I can fine tune EGR control to improve part throttle efficiency. I also want to play with antilag a little. Nothing serious just some timing retard and enrichment then crack the valve open for a moment when I let off the break to allow a shot of that miniscule 5lb of boost I'm generating into the exhaust. I don't necessarily want more than 5lb when break boosting because that gets difficult to hold back even if I pull timing during a launch but a bump response as I let go would be nice. Any in depth details as to the fit and operation would be much appriciated.
