arfbarkyPrime
- 62
- 36
- Aug 27, 2022
Ann Arbor,
Michigan
I have an ECU with ECMlink ready to install, and the olde SuperAFC to remove. I'd like to go ahead and put a wideband sensor into the stock location. Which one should I get in this day and age? I don't need fancy (I looked at PLX DM6 and that seems complicated and overkill), I need simple and works properly/non-fiddly with ECMlink.
It seems these wideband ones get wired into a module, then from there into the ECU? When you take out the narrowband sensor, do you just leave the harness connector, like zip it up somewhere?
