myblack98gst
- 578
- 1
- Jun 22, 2003
Elizabethtown,
Kentucky
I am assembling a 6 bolt with VERY limited time frame. I have everything except the factory gasket that goes between the block and front cover. with the factory gasket the passages that are half exposed on both pieces are seperated by the gasket but have holes at each end.
Does the configuration of the gasket serve a particular purpose or would it be possible to use a HIGH grade gasket material on the mating surfaces>?
any help would be HIGHLY appreciated
