pantaREi
- 39
- 0
- Oct 19, 2002
Turkiye
I'm thinkin to use IHI VF34 in my Gsx.Its about $ 750.00 and more powerfull from B16G.
It can fit to our manifold with little changes.
IHI-VF34
Type: Roller Bearing
A/R Ratio: .63
Wastegate Actuator: C484
Compressor Specs:
Outside Inlet Diameter: 60mm
Inside Inlet Diameter: 47.9mm
Wheel Blades: 6
Turbine Specs:
Turbine housing: 9.4 PZ18-H
Turbine: 94001
Turbine Blades: 11
IHI-VF34
A/R Ratio: .63
Compressor Specs:
Wheel Blades: 6
Turbine Specs:
Turbine: 94001
Turbine Blades: 11
