Mitsuturbo
- 87
- 5
- Feb 5, 2003
Seattle,
Washington
FIrst off.. this was done on 17psi, 91 Octane, and 34deg IATs. (yes, utah is THAT cold right now)
Ran some quick logs on the car last night, and i "know" my o2 sensor is pretty well shot, changing it tonight most likely, but my question is this.. do the o2 voltages affect how much timing advance you're getting? I assume they do, since it's the ECUs ONLY way of knowing how rich/lean things are running. Since my o2 is peaking at like .76v, i am speculating that this is why i am only seeing like 14-15 deg. timing advance. Correct?
this was with ZERO knock as well.. in case you were wondering
I lowered boost to 9# and got 22deg of advance, (saw the same o2v) so i'm left wondering if the ECU isnt comparing Hz to o2v and basing timing from there
I know the 2g is stingy with timing and basically "pulls" timing on the higher airflow maps. I have been told by a great many people that the 1g/GVR4 is not like this.
Thanks.
91 GVR4, 8.8:1 compression, Ported head, evo3 big16, 3" turboback, 550's, 2g maf, SAFC, SITC, DSBC-R, Apexi EGT
Thanks.
