Please Support ExtremePSI
2G Idle switch reading 0
Sam's GSX
5+ Year Contributor
394
54
Jun 10, 2018
Hohenwald, Tennessee
Sorry I couldn't find anything on this (even after searching "idle switch dsmlink")
But at idle my "idle sw" reading is 0, I believe that's idle switch, I don't know what else it could be.
Is there a way to fix this? I'm guessing something like the TPS or isc.
Any help would be appreciated
There are several ways to fix depending on what's broken.
First make sure that DSMLink is set to use the idle switch and not simulating it. There's a check boxes for that.
The next would be to adjust the TPS so the that Idle Position Switch inside activates per factory specs.
