Oldsid
Supporting VIP
- 207
- 4
- Apr 26, 2006
Calgary,
AB, Canada
I just finished installing a cyclone manifold using my original throttle body and an RPM switch. When I tried to start the car, the RPM shoots to 3000 and then drops quickly and then dies. Before this install, the car was running fine and I never had any idle problem. I checked all the manifold line to make sure that they are either connected properly or plugged. I only used OEM gaskets for the manifold and throttle body. I took the RPM reading from the power transistor wiring(Pin 4 white wire that goes to pin 109 on ECU) and I used a soldering connector .
I have checked and rechecked for anything that I may have forgotten but everything was reconnected properly and I am really stumped by this problem. I would like to know what would happen if the RPM feed to the ECU is bad. I will recheck the soldering tomorrow to see if it is the cause. I should also add that I removed the EGR and plugged off the lines on the throttle body.
Any ideas of what could cause this problem?
. Glad you got that working. How long ago did you order from JNZ? Do you have the link to the part on their website (i for whatever reason can't find it)?
