914 Cheeko
Jul 10, 2018
Newtown, Connecticut
So i was removing my shitty IAC valve that came with the engine from DSM and when i tried slowly pulling it out the whole thing split apart into 3 sections (so far.) The first pic is how it came out once I unscrewed it. The second is what was stuck at first, but slid off. Now I'm stuck with the valve itself stuck in the port (third picture.)
How do I get this out? I'm afraid if i try pulling it out any harder than I tried it's going to break a piece off into my engine. WD40?
So am I f***ed or how would I get it out?
You're screwed (you unbolted the wrong bolts you twaat) . There are still 2 more bolts behind the half of the sensor you removed
Remove those two screws so the hole looks like this
Well f*** me in the ass I got the wrong IAC too.
How so? There are three, the 90 style, the original metal 91+, and the new plastic 91+ version. The 91+ plastic version is the preferred version if you have a 91+ ISC/IAC since it's less likely to short out and damage your ECU.
Yeah it had the brown one. I am installing a newer black one hoping that fixes my stalling issue.
Post a picture of this part you speak of.
Did you use a screw driver or an 8mm socket?
It was the front/top of it without the part that attaches to the manifold. I was able to get the part off that this replaces but I couldn't get the rest of it off where the valve was, so it wouldn't fit. I used a screw driver because it had the rounded edges, it won't fit a socket. The full part does though. The full part has 2 bolts, this one has 3.
What's up with the 3 bolt flange on the one you are showing? That looks like the one used by the Evo 8, which has a 3 bolt flange.
I know like nothing about GVR-4, but Rock Auto shows the familiar 2 bolt flange ISC/IAC for the 1991 GVR-4.
Rock Auto has good pics what it should look like. Usually their prices are good too, but I see the price on this item has doubled since I bought mine about a year ago!!
Anyway, here, the IAC section for your car:
https://www.rockauto.com/en/catalog...,fuel+&+air,idle+air+control+(iac)+valve,6072
and here, the "info" for the Airtex/Wells. That picture, you can scroll through it, there are 5 pics there.
https://www.rockauto.com/en/moreinfo.php?pk=944131&cc=1103050&jsn=10
But for the 1991 Talon, they still list the Standard Motor Products "AC146" for less than the price a year ago.
This is what I expected to see for your car. I don't know why they don't show it there. But this is what I have in my car, the Standard Motor Products AC146. It seems fine. I just had to swap some wires around because mine is a 1990.
The 3 bolt one is only half of the IAC for the 2g 4G63T I have. The other half that connects to the intake manifold that holdes the actual valve in place has 2 bolts. It doesn't have the stock GVR4 engine, it has a swapped Eclipse GSX 4G63T.
