v8killer
20+ Year Contributor
- 372
- 5
- Oct 4, 2002
harlan,
Kentucky
like the title says i need a pic of a 1g timing table so i can convert my 2g timing table in tunerpro. Thanks !
what do you mean buy good fuel? VP STREETBLAZE, 93 PUMP,CORN. ?Man I love the 1g timing map. Its almost perfect when running good fuel. I just like to run 22* solid after 6000 rpm.
Why don't you try the evo map? A lot of people love it.
Stock evo map: http://www.ecmtuning.com/images/foru...2003-stock.eda
A slightly modified version of the 2003 EVO8 map that works a bit better on high boost/quick spool cars: http://www.ecmtuning.com/images/foru...-2003-mod1.eda
Yes, the low timing definitely helps the spoolup quite a bit. I use the 2g map until about 3k if i remember correctly and then ramp it up top
The 2g map is better at spooling turbos though, I love the low timing at spoolup since it makes it considerably quicker.
