Bart A
- 0
- Sep 5, 2013
Bloomington,
Indiana
I have completed a 2 year building process of my version of an Ariel Atom. I am using the exact engine with the exact same AEM computer along with the same ignition box that I removed from a running 95 talon. I am also using same gauges, sensors, everything. I have had the engine running but it is very rough and will not take fuel so therefore rpms will not build. It is probably safe to say that I have something small wired wrong..
Another bit of info: I have somehow managed to pop a 40a fuse that is feeding the AEM and injectors. I have replaced the fuse but I havent tried to start again because there is obviosly something wrong and i havn't had time to find out what it is.
So basically if you are in or around the Bloomington IN area and can lend a helping hand it would be GREATLY APPRECIATED !! I do have a lap top with AEM program downloaded in the garage. Unfortunately I don't know how to use it and to old to learn.
I should probably leave these computer cars to you kids.
My phone number is 812 320 - 2396
Thanks
Thanks
