TalonSpeed
- 526
- 21
- Dec 22, 2002
Little Rock,
Arkansas
Today for some odd reason, I lost 2nd, 4th, and reverse in my car. I was making a turn and decided to down shift into second. The gear engaged by the shifter felt real mushy, like cotton. I pulled over and noticed all gears that are toward the rear of car (2,4,Reverse) are VERY MUSHY, and wont engage. All gears toward the dash (1,3,5) are fine. Now I can sometimes get the gear to engage, but can barely feel it. I think the shifter arm cable is busted. I dont think the transmission is busted.
I just had a new clutch put in less than a year ago, I changed the transmission fluid 6 months ago and I installed a shortened stock shifter arm in two months ago.
Now here is what it is really doing. I took the console off.
There are two shifter arms. One on the left (side cable) and one on the right (center cable). The side cable is what designates from left and right. The center cable is what designates foward and backwards.
By center cable is busted I think. It only works for the forward gears. When the car is off I can move the shifter into any gear, like it should be. But when the car is running I am not supposed to be able to shift into any gear unless I depress the clutch. This is true but only for 1,3, and 5. Thats right I can move the shifter to 2,4,r with the car running, and clutch unpresssed, but they dont engage.
Where can I get a new shifter linkage from?? How much Satan gonna rip me off now?
