I hit the Gas Pedal and in middle of Reving it kind of stalls
ELITEAI
Oct 2, 2002
In the middle of me hitting the Gas Pedal and reving up it seems to kind of STALL and then it continues Do any of you have any suggestions on what this might be??? To me it seems like there might not be enough fuel be supplied (maybe!)
Thanks
Go with the simple stuff first. e.g., fuel filter, plug wires, and plugs. You can use a volt meter to test your plug wires, coil pack, TPC, and ISC. A shop manaul or Chilton's has all the resistant specs you will need. I can look them up if you need them or send you the shop manual. PM me if so.
make sure your ic piping doesnt come loose on boost. i had a problem where my lower ic pipe would break open from the coupler just a lil bit at 16 psi and the car would studder about 16 psi. sucked cause a yellow corvette wanted to race me that day too :)
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Price is shipped USPS flatrate. Message 702-741-6987.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $240 + shipping and PayPal fees* just replaced the upper bushing with...
  • For sale 4G63 Heads/ head parts
    Heads/ head partsNever ran ready to bolt up 1G head Ferrea dual valve springs/ retainers...
    • Dsm_canadian_mike
  • For sale 2g 2G Spare Tire Trim & Tool Pouch
    2G Spare Tire Trim & Tool Pouch $40 + shipping and PayPal fees* tool pouch has the tools...
  • For sale 2g 2G AWD Fuel Filler Neck
    2G AWD Fuel Filler Neck $65 + shipping and PayPal feesYou must be registered to see...
