Please Support STM Tuned
Please Support Rix Racing
I am STUMPPED!
95tsiawd11s
79
Oct 23, 2002
Lumberton, New_Jersey
OK, since I got my motor back, it took a while, but it seems that while just cruising at about 10-15 percent throttle, the car will bog down as if getting too much fuel. Sometimes you can press in the clutch, rev the motor and it will clear up. Then two minutes later it will do it again. Sometimes it doesn't clear up. But when you come to a stop and then start off again, it is gone, until two minutes down the road. I thought it was my tps. Put a different one in, still the problem. Here is the kicker... If the tps is disconnected, the car runs perfect, besides running extrememy rich and funny idle, but the problem goes away and never comes back, until you plug the tps back in. I tried resetting the ecu, worked a couple times, but it doesn't phase it anymore. I looked at the ecu, looks fine. Sorry for the long post, but my mods have changed, I am running HRC s20G, 650 injectors, 255 pump, safc, je 9:1 pistons 1G big rods, 6 bolt, and stock cams.
I was told that it might be because I don't have the web cams anymore. I have an HKS 264 intake cam, waiting for the exhaust cam. Would it hurt to put the intake cam in with the stock exhaust cam? Your help is greatly appreciated!
