LightningGSX
- 627
- 6
- Jan 15, 2003
St Paul,
Minnesota
Well ADC resolution is meaningless here.8 bit resolution is about 0.019 volts,deviations in the 5 volt ref or ground ref can easily be greater than 0.019 volts which would the shift the lookup table.Which is not neccessarily the case here.With a quick test ,with a snap-On Vantage waveform viewer and a 10 guage wire with aligator clips,I can see electrical system noise is probably the issue here which(you being an ecm designer would know) can cause all sorts of problems.Now I'm sure your gonna say, the ECM is filtered for noise which is true.But I doubt the OEM's add any more filtering than they needed at the time and by adding less suppressive plug wires or by the overall age of vehicle,engine,alternator electrical system noise will increase.This is still pretty much speculation, but I'll stick by my previous posts and I will say again I'm NOT making a case for buying these pre-fab wires.By the way who do you design for? firmware or electrical?
Some of us don't have such quality equipment, and have to resort to using scopes that measure in the MHz range.
